If I make a feature, say a ,1875in cube. and I "show dimensions" and because of manufacturing considerations I decide to change that .1875 to two a place decimal. Now my "nominal" dimension IN THE MODEL is .19. What possible use is this? Pro-E has more poorly thought out practices than any software I have ever encountered. I suppose the answer is to NEVER "show dimensions" Which is how PTC will tell you it should be done. This is just ONE of many examples of how Pro-E fails to meet expectations. How about that hole wizard!
What a P.O.S.
But I do have a beef with PTC on 2 counts:
1) This behavior has changed.In older releases, Pro/E would not change the nominal when the number of decimal places changed.
I guess my point is that I can NEVER use "show dimensions" which is THE only fast way that I can populate the drawing quickly with dimensions. You can't see a problem with my designing a feature to be 5/32 long and wanting to indicate a two place decimal on the document I describe the part to a machinist.I donot want the damn thing to CHANGE my model from .15625 to.16. I'm notwanting to changethe nominal that I designed the feature. I just want the machinist to bid me a two place decimal instead of the accuracy the is associated with a five place decimal. If my machinist is using the model to create the part. I wantthe modelto BE 5/32 (.15625) and not .16.
Let's take it to an extreme, if I build a feature that is 1.625 and I round it to no decimals I'll have a two inch feature. You can't see a potential problem here that is completly avoidable?
Why round off a decimal in a model. That should ALWAYS have the highest accuacy that I MODEL it with regaurdless of what the drawing says.
Again, I ask; What possible use is this?
Rich,
So you get exactly what you asked for. Why have a vendor quote on a part with 2 decimal place accuracy when you really want 3 place accuracy? What purpose does that serve?The vendors we work withneed to requote the job when you tellthem everything needs to be 3 place accuracy when the original quote was 2 place accuracy.
Rich Serafin
Point taken.
I suppose there are some considerations that I had not taken into account.
Thanks for your comments
