When I want to save as stl file it dose not appear in the option list.
JC_11033391
Hi there, I used Creo Parametric Version 9.0.3.0.  I don't have stl option when I click "save as". Dose anyone have this same issue? Thank you in advance for your help!
(To:JC_11033391)
As I suspected, no solid geometry. You are not able to export to STL from Creo without solid geometry in the model. Check with a solid part and you will see the STL option. If you see it with a solid part, then it is not a licensing issue.
I have never seen any license of Pro/E or Creo Parametric that did not support export of STL format.
7 REPLIES 7
(To:JC_11033391)
Are you certain that when you are attempting to save as the active model has solid geometry in it? Check that and report back here.
Dale_Rosema
(To:tbraxton)
You also don't have
-CGM (*.cgm)
-Render (*.slp)
-EDMD (*.idx)
-Medusa (*.asc)
It seems only surfaces in the part. Once there is only surfaces the stl option won't show up?
(To:JC_11033391)
I tried with other part which content a solid body the stl option shows up. Thank you for your quick response and answer!
BenLoosli
(To:JC_11033391)
That option will depend on what level of licensing you have, I think.
It does appear in my Design Advanced license and I will venture it will be in the Design Advanced Pro. too.
Thank you!
