Which tool to use to create this shape (swept blend?, sweep?)
gbro
http://i.imgur.com/5X9Kgom.png
The picture above shows the outline of the shape I'm trying to make. I need to make a solid object starting from the squiggle shape, along the straight line which is the trajectory, and to finish into the square. I think the swept blend needs objects with the same number of sides to create this which it does not have, so how could I get around this? Thanks
mpeterson
(To:gbro)
I used the boundary blend tool as I tend to gravitate to that because in the long run you can continue to modify your curves to control the transitions better. Hard to tell what the intent is one how this shape transitions from a square to a squiggly line. Attached is my model where I kept it simple to start and just use curves in one direction and then used control points to align points on each curve with the associated points on the other curve. If need be you could create curves in the second direction connecting specific locations between curves and also possibly making the curves in the second direction not straight with their own curvatures. The image is a view of the attached CAD file.
10 REPLIES 10
mpeterson
(To:gbro)
Swept blend requires the same number of control points, not the same number of sides.  It the example that Mark posted, he added points around the square to make it match the number of control points on the "squiggly line" enclosed shape.
Patriot_1776
(To:gbro)
...or you could use a VSS.....
Patriot_1776
(To:gbro)
...Like this surface (easily "closed" to be a solid)....
Frank,
In Creo, the VSS command is gone; PTC reworked the sweep and blend commands.
Regardless of all that, what did you use to generate that render?
Well, I'm on creo elements/pro 5.0, whatever the h3ll that means now.  I know it's a couple revs behind.  Hopefully they have taken the VSS capabilities and just moved them.  It's one of their most powerful tools.  If it's gone, I'm gonna be totally p!$$ed.
Just added a color and turned on the "Enhanced Realism) with the shade quality set to 10, nothing special.  I'd rather put my effort into the model, not the rendering.
All of the functionality of VSS is still there, it is just under the Sweep and Swept Blend commands now.
I spend all of my time in shaded with edges (aka, Cartoon Mode) or Hidden Line that I forget there are other settings.
Unofficially WF5/Creo Elements is called "Creo Zero"
F000 of the F000?
Isn't there a band called the F000 fighters?
