Why are all my appearances dark?
StephenW
Why are all my colors extra dark? I believe this was the appearance.dmt from our internal cad support people when we moved to creo 3.
StephenW
(To:StephenW)
So my specific problem had to do with an option;
pro_texture_library
Once I removed that option, my colors all came back to reasonable.
14 REPLIES 14
STEVEG
(To:StephenW)
Stephen,
I actually have the opposite.  My Creo 2 was darker.
StephenW
(To:StephenW)
I noticed if I clicked the rendered samples, it's much better.
STEVEG
(To:StephenW)
Not much of a difference for Creo 2.
I had similar problem in CR3. I installed current version of graphics drivers and problem has gone...
MH
Hi Stephen,
I checked on mine and my colleague's machine.  The appearances appear brighter in Creo 3.0, than in Creo 2.0.  I also checked remotely on another machine, and saw that the appearances were darker in both releases.  I believe the graphics card may also be playing a role.
Amit
Similar issue here since switching over to Creo3 M080 and mine are all black except one.  If I select rendered samples the colors appear, but are very dark.
StephenW
(To:GaryBunney)
Wow Gary, yours are EXTREME!!
StephenW
(To:StephenW)
Tomorrow morning I will try removing all my config files and see if it's something I have purposefully set for a different reason. If I don't find something there, I will try Martin and Amit's suggestion of updating the graphics drivers.
My card is an Quaddro 2000, around 2-3 years old now. I'm sure I've updated the drivers but probably not since the creo 3 installation so that's definitely a good possibility.
StephenW
(To:StephenW)
pro_texture_library
doneill
(To:StephenW)
I have the same problem with Creo 6, but I don't see a "pro_texture_library" option anywhere.
StephenW
(To:doneill)
Seems like that option was maybe replaced with texture_search_path
I'm not sure that's a true statement but you may want to look and see if you have that set and temporarily remove  it and restart Creo to see if it improves.
The way I solved this initially was to remove all my config.pro files and start Creo. When the problem was gone, that told me it was definitely a config setting.
Then I cut away 1/2 the config and I figured out which 1/2 had the problem setting. Then I cut that partial config in 1/2 again and again until I could tell which setting it was. It probably took less than an hour to do this.
What helped for me was removing the
GRAPHICS WIN32_GDI from my config.pro
After that everyhting became clear again.
(CREO3 - M130) We have the same problem of color too dark and the menu of the render is very very slow to appear
In our config.pro we have : GRAPHICS opengl
StephenW
(To:ldrutel)
Did you try the posted solution?
Remove the config.pro option pro_texture_library and see if that helps.
Opengl is the prefered and default graphics option and normally gives you the best performance
