With the search tool I would like to select all the components which have for designation_1 = "hinge
MG_9638468
6-Contributor
With the search tool I would like to select all the components which have for designation_1 = "CAISSON"
But I can't find the category ...
to find parts/subassemblies containing specific model parameter (not component parameter), use following search "command".
Martin Hanák
7 REPLIES 7
Look for Part>Expression. I'm not sure why it's called "expression" in the Search Tool when it's called parameter everywhere else.
MG_9638468
6-Contributor
(To:lhoogeveen)
that's what I'm looking for! on the other hand I can only find the parts with this solution I cannot find the assemblies ?
Look for components instead of parts. This should get parts and assemblies that are present in the top level assembly that you are searching within.
21-Topaz II
(To:tbraxton)
I tested this in Creo 7 using look for components in an assembly but that only returned .asm models. This was not as I expected, if anyone can explain why I, am interested to know.
In order to get the desired results I built a search query that looks for components and parts.
Look for partsLook for partsLook for componentsLook for components
Martin Hanák
It's exactly that !
thank you so much
Trebla
(To:MartinHanak)
Thank you for sharing this Martin. It is so powerful!
