Wrench and Socket clearances?
BrentDrysdale
7-Bedrock
Hi Folks,
I have used my trusty Machinerys Handbook (20th Ed 1975) for
this information when I have needed it but one of my colleagues asked if
there was a more elegant way such as ProE (Creo) models?
I did a bit of searching and found more tables and even some nice Metric
ones but nothing model related to clearances. I saw reference to the
Standard ProE Libraries but am not familiar with them and if this might be
buried inside (and Help wasn't).
The only wrench reference I can see on the PTC site is in Creo illustrate
which we don't have.
I searched my back exploder email and Planet PTC and CreoCommunity to no
avail.
Anybody have any clues?
I could go and add a clearance surface to our fasteners library based on
tables but the thought of re-inventing the wheel is not that appealing when
I have real work to do.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
0 REPLIES 0
