Zero QTY Relation
TerryMcFall
1-Visitor
Zero QTY Relation
I have an automatic BOM drawing table that will generate an qty of zero. I'd like to write a relation that will display the text string "REF" in place of zero qty.
Is this an easy thing to do or am I asking for the moon? Can anyone recommend a good resource to learn about relations? The tutorial on ptc.com is pretty brief.
-Ter
Terrence McFall
CAD Systems Administrator
Varian Medical Systems
Palo Alto, CA USA
650-424-6039 desk
650-799-0179 cell
TomU
(To:TerryMcFall)
Best resource is probably the help documentation. This is actually pretty straight forward. You simply check for the value you want (in this case zero), then set a second parameter equal to it or to something else when that value is found. Just make sure you change your table cell to look at this new parameter instead of the original quantity. (&rpt.rel.QTY2)
IF rpt_qty == 0
QTY2 = "REF"
ELSE
QTY2 = rpt_qty
ENDIF
It also is helpful to use the "IF EXISTS" function anytime you aren't 100% certain the parameter will always exist. Here is a sample from a different thread:
