Is there any setting you can use to adjust the thickness of the lines in printed drawings from ProE?
Changing drawing line thickness:
· Click on layout tab.
· Click on line style.
Pen tables is the typical method to control line weights for plotting.
There are several useful discussions here on the forum regarding this.
This is also a good link if you have access:
Use the pen table , to control line
Vijay
Hi Sudhir...
Refer to this conversation about thickening/thinning lines: http://communities.ptc.com/message/173175#173175
Also, refer to the attached documentation to create and activate a pen table file. I believe all the information you need is in the attached documents.
Thanks!
-Brian
