assembly
Albert_Le
assembly
Please who can guide to me about in assembly 01 part can use with many parts. how I can control when assembly that part and save but do not generate new part. that mean we can control 1 part for using a different assembly part
StephenW
23-Emerald II
(To:Albert_Le)
I don't really understand your question. Maybe you can provide an example of what you are trying to do.
Maybe you are referring to a situation like a spring where the same spring can have different lengths based on the assembly it is in. In that case you can use flexible components to control the spring length.
Albert_Le
(To:StephenW)
Dear
I want to learning about assembly
When i use 1 component for assembly for 2 assembly drawing and save then that component will generate new name
Ex: A +B =C
A+D = F
But Part A when save automatic changed the new name
How i can control that mean if i save A in folder then i used it apply for all assembly when save part A still keep in the location at the folder
May you can understanding my explain
