assmbly refererence problem in Pro/engineer wildfire4
ptc-5235788
we are using pro/engineer wildfire4, we created one assembly and assembled the family table instance parts of different lenghs in that assembly, the section of all instances are same only length is vary. then we fix the length of parts in assemby by assembly parameters by adding relations. now what happend is when we change assembly parameters, the length of instances did not change.please help me how can i do...
thanks
Does WF4 have flexible components?
SylvainA.
(To:ptc-5235788)
It seems that you need to have flexible components (components' dimensions can be changed in one particular assembly). You can have a look at "make flexible" in Pro/E help center.
It would be easier to help you if we could know why you want to change a part's dimension using an assembly parameter...
