best practice for materials assignment
gbon
I've tried several times to use material assignments with colors.
When assigning material to a part, sometime it take the material color
preset and sometimes not.
I can't understand what I'm doing wrong.
So, is there any document or explanation somewhere that would explain how to
use this feature correctly?
GB
sdesaulles
3-Visitor
(To:gbon)
Great that you ask a sensible question like this, and two years on, no answer.  I'm looking for the same thing - or rather how to rapidly assign materials in an assembly.
Hope you found a way..
