hey All,
is there anyway to add "new" local parameters and "new" relations to existing dwg bom repeat region with a mapkey?
trying to create mapkey do accomplish this but it does not work
tried loading a "new configuration" xml file with no luck either
thanks,
Rich
@rburk wrote:
Hey Martin,
mapkey works well for entering line of text, thanks
is it possible to use a mapkey to "copy/paste text" from text file?
Relations dialog box contains File > Import command, therefore you can load relations from text file.
Modified x3 mapkey loads relations from my_relations.txt file. See uploaded config.pro file.
@rburk wrote:
hey All,
thanks,
Rich
why you need mapkey ? Do you plan to do repeat region modification every day ? If I were you I would save relations into txt-file and Copy/Paste them from Notepad to Creo.
Hey Martin,
this would be done as daily updates on hundreds of legacy files,
was hoping to streamline with mapkey
mapkey I had created always pauses and end up having to finish steps manually
Rich
@rburk wrote:
Hey Martin,
Rich
in Creo 7.0 the mapkey saved in attached config.pro works well.
Repeat region before modification
Repeat region after modification using mapkey x3 ... see video
Hey Martin,
@rburk wrote:
Hey Martin,
