Is this type of attachment possible in PTC Creo? If yes kindly mention the procedure.
See this reply https://community.ptc.com/t5/3D-Part-Assembly-Design/ANSI-1982-Datums/m-p/687642/highlight/true#M28193 by Mfridman
Thanks for the link Stephen.
