I'm using wildfire 4 M180, but checked that the problem I have also occurs in wildfire 5 creo 2 and creo 3
I cannot open some?? of the bulk items that were created in the past. Maybe that's what I think it is
Upon opening I get an error:
I can assemble the bulk-type item into an assembly after reconfirming its re-use (never seen that before)
after assembly the bulk item appears in the model tree as expected
Recently created bulk items (like the blk0001.prt in the picture above) I can open.
as expected I see the this window:
When assembling this bulk item I do not need to confirm its reuse, it just assembles
questions:
Are there different types of bulk items ?
How do I make the ones that won't open behave like blk0001. (other then recreating them...)
background
I'm in a data migration process and I have tooling running doing a datacheck.
the migration software needs to open the file and read parameters
found this case
ptc case CS99332 |
which has a resolution that in my view doesn't make sense :
I hope you are able to knock some sense into this ?
Thx Liek
