create layer with file name?
Inoram
Is there a way to create a layer in a part with the name of the file?
If not, is there a way to maybe do it on export?
Hi Matt,
I don't think this is possible.  You could create a mapkey, that creates the layer, but it would require some manual input to enter the layer name.
Amit
