create twist along a sweep / extrude
vdevan
i have a profile like i have in the image.
i need to twist the profile fro 2 rotations , (360*2) along the path for 100 mm ..
can any one suggest an easy way to do this...
Blend is one option, but when i tried i could not rotate more than 360deg (one rotation) ..
kindly help if possible
Thanks in advance..
John.Pryal
(To:vdevan)
Hi, hopefully the attached model will help you achieve your goal.
Good luck!
John
John.Pryal
(To:vdevan)
There are a few ways this could be achieved. By relation using trapar or using 'Warp' feature with twist. I have attached a basic model showing technique. Good luck!
John
vdevan
(To:John.Pryal)
Thank you for the model, it was helpful.
however i thick sweep using relation would give perfect results than warp.
i tried to form a relation with the angle and trajpar, but i couldn't get the desired result.
if possible, can you help me with a relation.,..,?
Thanks for your help .. .
mcestnik
(To:vdevan)
Blend could work if you add intermediate sections...added an example part.
vdevan
(To:mcestnik)
hey, thanks for the model..
however i could not open it , i get 'EXAMPLE' cannot be retrieved.
there are more than 1 ways to achieve ..i am just looking for a simpler one..
and i think model shared by John is bit simpler than using blend and multiple sketches.
Thanks for your time and effort .....
John.Pryal
(To:vdevan)
Good luck!
John
vdevan
(To:John.Pryal)
Thank you ..
that is what i was looking for ..
Thank you for your time..
