Using the appearance manager I made a new appearance, map tab, colour texture set to image and then imported an image to display it on a surface. I then check this component into windchill however the image gets lost when my colleague opens it on his computer but does not get lost on my computer.
any ideas?
thanks
gord
When needed, I always do a Find command within the Configurations editor and search descriptions.
texture* was my keyword search.
Use this config.pro option.
save_texture_with_model YES
Thanks Peter, worked a treat and will save me a lot of time!
