ive searched, and cant find a solution. creo 3.0 M120 crashes when i try to save as a .pvz file. the assembly isnt even that large of a file. any input?
Similar question before - "System crash while saving pvz file": https://community.ptc.com/t5/3D-Part-Assembly-Design/System-crash-while-saving-pvz-file/td-p/669172
Hello @dgrobe
You may want to attach the traceback.log probably generated on disk to this post for further review.
Alternatively, you may want to:
If above is useless, and not trabeack in your working directory, as a general rule for this kind of "data specific" questions, it will be difficult to provide further guidance without access to the impacted data. Considering above:
Serge
