creo_parametric_customization.ui file iterations
sk-10
I been working on drawing programs to control our draft entities visibility "more like automating a set of draft based drawing". This means I don't use a model but would use a part file that supports the states (yes/no).
We have a exisiting custom creo start file that does work fine with all those drawing program in it that controls draft objects visibility.
Now that we are creating a new creo start file, we are finding hard time to merge the old ui file and new ui file into one ui file.
Would there be a option to have two ui files, which would only open up in their corresponding creo start part file??
SARAVANAN
0 REPLIES 0
