default surface finish value
thlavinka
Is it possible to change default value of new created surface finish sign in drawing?
Thanks in advance
T.
Create a new symbol using your preferred value as a default.
I created a reasonably comprehensive SF symbol I use.
Comprehensive Surface Finish Symbol
Attached: Creo 2.0
Tomas,
Could you please explain this in detail? Are you referring the default value 32 for surface finish?
Yes exactly.
Attached: Creo 2.0
TomU
(To:thlavinka)
Mapkeys are your friend. Make one ("sf") that places the symbol (OOTB or custom) and automatically sets the value to whatever you want.
tleati
(To:TomU)
Hi Tom,
Thanks for your tip, I think it's the best option.
I just tried to mouse record that mapkey, but it doesn't take the value I had put in in the recording script....it keeps the original 32.00.
Could you post your mapkey script? I have Creo Parametric 3.0 M130.
TomU
(To:tleati)
Here you go.  This one changes the value to 16.
mapkey sf @MAPKEY_NAMESurface Finish;@MAPKEY_LABELSurface Finish;\
mapkey(continued) ~ Command `ProCmdDwgCreateSurfFin` ;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist` 1 `generic`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist` 1 `generic`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist` 1 `standard.sym`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist` 1 `standard.sym`;\
mapkey(continued) ~ Select `drawing_sym` `tab_main` 1 `lay_var_text`;\
mapkey(continued) ~ FocusIn `drawing_sym` `inp_gtolchar.0`;\
mapkey(continued) ~ Update `drawing_sym` `inp_gtolchar.0` `16`;\
mapkey(continued) ~ Select `drawing_sym` `tab_main` 1 `lay_general`;\
mapkey(continued) ~ Activate `drawing_sym` `OK_push`;
