the dimension digits and tolerance digits must be the same for wildfire2.0?
2.05+0.02/0.00
it is possible?
2.05+0.020/0.000
how?
is there anyone can help me with that?
the digits number of dimesion ans tolerance must be the same?
there is a option to controle the tolerance digits number
&linear_tol_0_000 3 digits but only 0.001 even your tolerance are 0.235
i got 20+0.24 0.001,the 0.001 from &linear_tol_0_000
+0.00
Hello Linda,
There is a way to do like that, I think u want one decimal place for dimension and tolerance's.
ex:- +0.050
-0.030
200.0
If your requirment same as above, follow the bellow comands in Drawing options.
tol_display == yes
dim_trail_zero_max_places == 1 or default (Based on your requirment 200.0 or 200)
dim_tol_lead_trail_zeros == both
dim_tol_trail_zero_max_places == 3 or 4 or 5 (Based on decimal placess in your tolerance)
After applying this, change the Decimal placess in dimension properties.
Thanks & Regards,
Bhanu.
thanks for your reply.
which version wildfire do you use?
i can not use those options except tolerance_display lead_trial _zero in wildfire 2.0 because the apply botton is gray or the system has no option like those,in fact on option begin with dim_tol_
I was used previously WF-3 and 4.
Now I am using WF-5.
But I don't know about WF-2, beacuse I haven't used that. Those options are there in WF-3, 4 and 5.
Once u re-check it, may be it will be their.
Bhanu
