Does anyone know of a way to simply extract a set of surfaces from a solid part?
I'll ulitimately export this set of surfaces to be used in other software, so even if I could write a .stp file which only had surface geometry, that might work.
thanks in advance for any help.
greg
Don't forget the 'Solid Surfaces' option:
Select the first anchor surface, RMB, Solid Surfaces (all surfaces selected), Crt+C, Crtl+V
Bob, Can you expand on the Surface Only Model function - can't find any reference to it. Are you changing the properties of the newly created model in the .asm?
Cheers, Sean
