flattening cable assemblies
mbabu
6-Contributor
I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM190
we have issue on flattening some cables
Lars_F
(To:mbabu)
Flattening may be difficult for large harnesses. If your cable is routed correctly, without any errors, then there is a very instructional video series in youtube over the flattening process... https://www.youtube.com/watch?v=WVX_RNU4kSI
