hi Team,
could you please explain me how to create customized .rep & .fmt tables.
Hi Madhu,
in order to create .rep and .fmt files :
if you are using the same report table in all your designs -> add the report table to your template design and it will be automatically in any design which is created using this template.
Gaby
Your question is to generic what do want to report and how do you want to customize?
I want to make From To tables like below.
I've created from to tables from .rep & .fmt like below. this fromats got from one of my friend. I donot how to create new formats. please help me out.
If you search in the Help Center for "report table" you will find a lot of info.
Basic Tutorial (Get Started tab->Tutorial) also include useful example .
in addition, see attached video :
Hi Gaby,
I agree with your video, this one is every time I need to select and do.
what I'm looking here is I need to make this table as template for my all designs. I've created the tables using .rep and .fmt files this are predefined just I called this files into my design then it is populated tables.
here my question is how to make coustmised .rep & .fmt files.
your video showing From & To connection apart from this I need some other spool info.
Please let me know your free time. we can discuss in detail.
Madhu
Hi Madhu,
Gaby
Hi Gaby,
Thank you very much. It worked well.
could you please tell me how to add the report tables to template.
Thanks, Madhu
Hi Madhu,
if you are working in Creo schematics 3.0, all you need is :
if you are working on Creo Schematics 2.0 or older version :
Regards ,
Gaby
I can not see the video
Do you have Flash disabled? The video player requires Flash.
