how to create repeat region tables in 3d assembly
msonnathi
Hi Team,
I would like to make repeat region tables in 3D assembly/part model.
please could help me.
thanks,
Madhu
Madhu,
you can create repeat region tables in drawings, only. In assemblies, you can save BOM to text file and then import its contents into annotation. Unfortunatelly this annotation will not follow changes made in assembly.
Martin Hanak
Martin Hanák
Madhu,
Martin Hanak
Martin Hanák
Hello Madhu,
I fear Martin is right about report functionality being available only in drawing mode and his workaround is currently all we can offer.
Hence I am marking his post as Correct Answer.
It's a nice idea though, maybe someone should file a Product Idea!
Gunter
