i'm working in a model, and so far i know how to do family tables modifying dimensions, but now i want to know how to have a model with different features.
someone can help me out with this?
thanks
Add the feature to the table and change it's status to Y N or *.
Y resumes the feature
N suppresses the feature
* follows the suppress/resume status of the Generic (Not recommended)
If you suppress a feature in the Generic, then open an instance and create a feature in the instance, the feature is automatically added to the generic and automatically suppressed in the Generic, and is added to the table as Y only for the instance it was created in and a status of * in all the others. You can resume in the Generic or set the status in the other instances.
Note that if a feature created in an Instance is resumed in the Generic or another instance, it may fail if the references do not exist or the geometry is incompatible.
