how to export file from creo to nx ?
soganja
hello sir ,
please give me guide line for how to export file from creo 3.0 to nx ?
thnk u .......
VladimirN
24-Ruby II
(To:soganja)
You can export solids body in STEP format (".stp") and surfaces as a IGES file format (".igs") then for reading them in NX.
Mahesh_Sharma
22-Sapphire I
(To:soganja)
Sunil,
You can save Creo files as NX using File > Save as NX. However type Nx is license feature. If you have license for Collaboration_Ext_NX you can save files as NX.
Mahesh_Sharma
22-Sapphire I
(To:soganja)
Sunil,
Did you manage to export Creo data as NX?
BenLoosli
23-Emerald II
(To:soganja)
NX can also read Creo files, but not sure about Creo3.
It is also a licensed product like the Save_as to NX from Creo3.
ft-2
(To:soganja)
Another solution could be to convert your Creo files to NX with CrossManager : http://www.datakit.com/en/cross_manager.php
It is not free either, but certainly less expensive than a Collaboration_Ext_NX license.
You should compare the two possibilities.
