how to import jt & jt related BOM
xyan-2
2-Guest
we need creo illustrator & service part from TC PLM system , but we don't sure manu question below?
  1. Does windchill 10.1 support import jt & jt related BOM?
  2. Does visuralization server publish jt to PVZ batch and related pvz as repesentation SBOM?
  3. Does ootb or customization support it ,is there experience share to me ?
0 REPLIES 0
