We only just now upgraded from Creo 4 to Creo 7.
When running Model CHECK now, it opens in a separate stand alone window, which with multi screens pops up most often in a screen you are not working in. Is there a config setting to get the MC window to open "integrated" (not a stand alone window) in the model graphic window the way it was in Creo 4?
With Creo7, the ModelCHECK dialog/results box opens in a separate window. In Creo4, it opened integrated similar to how the workspace dialog as shown in yellow in the picture above. How to get mc integrated and not open in a separate window for Creo7? Is there a config option to set this?
