Use the solidify command under MODEL tab in the ribbon Editing section. For CUT, use the removal cut icon.
hello and thank you for your answer.i do know that but in order to do what you said i have to sketch on the drawing.but i dont want that.what i want is to use the blue surface as a sketch in order to cut it.but i dont know how to do it.i have to use references this won't help me
it worked!
thank you
i am on the final stages and i am struggling with the pattern.i want 3 pieces of the schematic below in 360 degrees.Do you know how to apply the pattern in order to be the same with the other image below??
Possibly, create an axis through the center. Select features you want to pattern. Select pattern. In the drop down menu of the pattern command, choose axis and then select the axis you created. You'll want 3 for the first value and at 120 degrees each
