is there any way to apply colors for non-driven spec tubes/pipes just by selecting the pipe segment?
Hi MB_10357724,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
This will increase your chances to receive meaningful help from other Community members.
Anurag
Anurag, I got a solution. Thank you.
To help other users in the future, post your solution here and then mark it as the solution.
