making a Cosmetic Tread surfaces vsible
gjackson
In WF4 I was able to create a cosmetic thread and it would come in as a transparent purple surface in shading view. With working in WF5 when I create a cosmetic thread the surface does not show up in shading view. however it will show purple lines in nohidden view. Is there an option thatI am not aware of to get cosmetics to be visible?
If it is can I change the color of the surfaces?
0 REPLIES 0
