Hi. I want to put the value of a paramter from my assembly in a drawing from this assembly. I created a table, but can´t manage to use this value from my assembly. I would appriciate some suggestion.
Thanks a lot.
Best regards
Edna
Does is have a repeat region?
I tried it that way, wit repeat region but still didn´t knew how to do it.
I know how to use repeat region, but I don´t know which one to select. Asm? Prm? etc. I have been using the parameters from the parts and the repeat region. I used asm then mbr then Used Define and then wrote the name of the parameter. But know I don´t know which one to select for a parameter from the assembly.
In a normal table (not repeat region), simply enter the assembly parameter name with an ampersand in front of it.
&DESCRIPTION
&material
&designer
