pdf export pen pattern Creo 8.0.5.0
SP_saro
The drawing must be exported as a PDF. We have phanthom and hidden lines in the drawing.
If I set the Pen 3 pattern . it will only accept one Line style.
(pen 3 thickness 0.010 cm; pattern 0.1 0.05 0.025 0.05 cm)
How could different line styles be used? Hidden line and Phanthom line both use Pen 3.
Please assist me in solving this problem.
@SP_saro wrote:
if the pattern line is removed, hidden line and the Phanthom line looks good.. but I need a different pattern for the hidden line and the phantom.
so it looks like you do not like default patterns assigned by Creo to hidden and phantom lines.
One possible solution = changing phantom component display. Please play attached video and use uploaded data.
10 REPLIES 10
what happens when you remove pattern 0.1 0.05 0.025 0.05 cm from pen definition.
SP_saro
(To:MartinHanak)
PDF Output
Drawing
If I can use the pen 3 thickness 0.010 cm; pattern 0.1 0.05 0.025 0.05 cm
Its shows hidden line also in phanthom line style.
once again ... remove pattern 0.1 0.05 0.025 0.05 cm from pen definition.
SP_saro
(To:MartinHanak)
SP_saro
(To:MartinHanak)
Wow, Nice Idea, I can use this option .
If we can change the Pen 1 pattern its not effect geomentry line and etc (below mentioned as Pen 1 line styles?
  • Visible geometry
  • Cross-section cutting plane lines: plot as phantom lines
  • Cross-section cutting plane arrows and text
  • Drawing format and boundary
  • Tag text
  • Centerline line font with white color
  • Brown portion of datum planes
Thanks a lot for your workout
  • Visible geometry
  • Tag text
look into pentable_02.pnt
pen 1 thickness 0.010 cm; color 0.5 0.5 0.5; pattern 0.1 0.05 0.025 0.05 cm
pen 3 thickness 0.010 cm; pattern 0.1 0.05 cm
pen 10 thickness 0.050 cm; drawing_color
... drawing_color keyword causes that Creo will draw visible geometry by pen 10 instead of default pen 1
You can use other keywords to resolve your needs.
Notes:
1.] All user colors are drawn by pen 1.
2.] All system colors have assigned their keyword which enables you to assign them specific pen.
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/data_exchange/interface/Default_Pro_ENGINEER_System_Colors.html
SP_saro
(To:MartinHanak)
Thank you very much for the clear explaination and your time .
SP_saro
(To:MartinHanak)
Hello Martin
Your choice to manually adjust the view color in Phantom_hidden_PDF.mp4 results in output PDF phanthom and Hidden line utilising the Pen table.
Can we choose a different colour for the phantom line and hidden line details in system color ?
Note: In system colour, I only saw only Hidden line color only
@SP_saro wrote:
Hello Martin
I guess you are asking how to change colors in Creo window.
Hidden Line color:
Custom color assigned to phantom components in Drawing mode:
See phantom_hidden_PDF.mp4 video again.
You can select any User-defined color -OR- create new one. AFAIK you cannot set user-defined color as default one for phantom components.
