pdf output from annotation and drafting should be the same
MichaelSpiewak
WE have had some propblems where an annotation file will get printed as a pdf file from annotation and it looks like expected, but that same file in drafting will load and print with a large amount of white space on one side of the border. The same file should load and print the same between the two applications.
drafting-pdf-plot.bmpPDF file from drafitng. using fit option.
anno-pdf-plot.bmpPDF file from annotation using fit option
0 REPLIES 0
