port limit on Schematics Lite?
amedina
I'm trying to do something simple. You gotta a 4 connector connector and a
4 wire cable, Connect them.... This works
Now do the same for a 50 pin connector and a 50 pin cable. AH no worky
worky. At PTC cables can only handle some random number of wires. 42 for me
today in this particular cable, this day/month/year.
Well if I start the cable from the bottom (pin 1) it routes up to 42 pins.
If I start from the top, it routes 8. Just not the two together in a single
cable.
Does anyone know WTF is going on? any pointers, ideas, clues.?
?msg_msg@Start the fiber by probing on a port or branch, or use the
shortcut menu to start in free space
?msg_msg@Choose a port or highway to terminate. Probe in free space to
route, or use the shortcut menu for additional options.
?msg_wng@Not enough ports to connect all cores
?msg_wng@8 cores not routed
?msg_msg@Probe the ports you want to select
[image: Inline image 1]
Ok found my answer. I changed the origin to the top left hand and that
fixed the issue. I totally forgot about that little thing.
I also forget to reset my engine's piston to top dead center before
injection and spark. Locally for me, a good company developed the engine in
my car and the computer does that automatically about 33 times per second.
Some companies should learn to automate for user convenience.
