In Creo-8 i am trying to make a quilt form with a surface sweep, but unfortunately, in creo-8 sweep always default comes with a solid, am not seeing an option to create a surface sweep. Due to this am not able to select the quilt form.
Dear @Anand_G ,
Good Evening.
From which tab you are creating the sweep feature.
If you want to create the surface sweep, then go for the "Model" tab and then select the sweep command and then you will get the surface option to create the same.
please let me know any update.
