"Insert here" bar missing
hwanho
7-Bedrock
I am using Creo Parametric - Release 8.0 (connected) 8.0 8.0.0.0
Hello
I can't see the "Insert Here" bar in the Creo 8.0.0.0
I attached capture files. Could you check it?
TomU
(To:hwanho)
Not seeing any files attached.
This is from Creo 8.0.0.0:
Starting in Creo 7 the "Insert Here", or Insert Indicator, was switched to the green bar. It behaves identical to the Insert Indicator in that you can drag and drop it to enter Insert Mode. Then RMB > Exit Insert Mode to exit.
Matt Huybrecht
Hello
see green horizontal line in picture uploaded by TomU. This is former "Insert Here" bar.
TomU
(To:hwanho)
Not sure if this is your case or not, but this article just rolled out from PTC:
https://www.ptc.com/en/support/article/CS345672
Kristof_D
(To:hwanho)
It's the same in Creo 7.
Go to the model tree settings and make sure "Features" is selected.
If you press apply, the bars should come back.
I'll log another case to E-support and suggest this as a change.
