"Set/add drawing" from drawing Shortcut menu.
jjackson-5
When on a sheet of multiple details in a .drw file, I used to be able to switch between parts by right clicking the view I want, then the shortcut menu would give me the option to "set/add drawing model" to the current view.
I would be able to quickly change the model shown in the model tree to the new model I need.
This seems to have disappeared in Creo3.
Anyway to get it back?
I bet carpenters would just love it if their hammers changed every few years and they were worthless until they learned how to use the new ones.
mender
6-Contributor
(To:jjackson-5)
The ability to change the model/rep shown in the model tree by picking a view was not implemented in the change to the behavior of the Model Tree in Creo 3.  This was fixed in Creo 3 M030 as follows:  in the Model Tree, and in the RMB for a drawing view, adding a command Use Model In Tree.
Separately, there was a problem that caused some cases for Set/Add Drawing Model to be missing that command, notably in the RMB on the selection of a part in an assembly view.  This was cleaned up in Creo 3 M040.
StephenW
23-Emerald II
(To:jjackson-5)
I still get the SET/ADD DRAWING MODEL in my right click, unless the view is already on the currently active model. Creo 3 M040.
I'm using M020.
Here's a pic of what I'm looking for.
In this pic, the current model is set to the -84 part as shown in the model tree.
I want to set the -42 part to current.
I used to highlight the view of the -42 part and right click. The shortcut menu would then have and option "Set/add Drawing Model" option.
That appears to be missing in my version.
I have looked in the File>Options>Shortcut Menu and the option is listed under Compenent>Primary and it is checked.
But it is not listed under Drawing View>Primary,Object Commands or Properties.
And that where I need it.
Thanks for any help.
mender
6-Contributor
(To:jjackson-5)
Thanks for the info.
