setting up pre-established drawing views
BrianStoddard
At a previous job, whenever a new drawing was created, it had pre-established views already setup in the drawing (Front, Side, Top, etc). Can anyone tell me how this was done so I can set up my drawings this way?? I'm using Wildfire 3.0. Thanks.
Hello Create a new drawing file, de-select the default template check box, pick empty, press OK, go to "Applications" on the top tool bar, and pick "Template", then go to "Insert" on the top tool bar and pick "Templete View" from there you can create all your custom views, dims ect.
The front, right side, and top will be the default views if the part is active before you open a drawing file, but with the afore mentioned you cam custom make views.
