sticky simplified reps...
nrollins
Hi all...
WF4...
I have an assembly. A component of that assembly is another assembly. For
the component assembly, I set a simplified rep to use.
How do I get the main assembly to open with the component assembly in the
simplified rep that I chose? I have to re-do it every time I open it.
Thanks!
Nate
jstone
(To:nrollins)
Nate,
Set up the default rep in the main assembly with a substitution rep of the sub-assembly. Save with the default rep active.
jef
