In wildfire what is the DTL config to show trailing zero's?
Also the config to have a limit dimension to be one above the other?
This is from the Help Topic Collection for WF4 in the Detail.pdf. Everyone should download these documents for reference!
lead_trail_zeros
Controls the display of leading and trailing zeros in dimensions.
• std_default*—Displays only trailing zeros. No leading zeros are displayed.
• std_metric—Displays only leading zeros. Trailing zeros are not displayed.
• std_english—Displays only trailing zeros. Leading zeros are not displayed.
• both—Both leading and trailing zeros are displayed.
Also, ASME Y14.5 does not allow the use of trailing zeros for tolerance place holding if you are using metric dimensions.
lead_trail_zeros
