transparent view, chamfer
emathivanan
how to get the transparent view in part?
Difference between Distance*D Offset*O.. In a diagram can anyone explain?
You are trying to set a transparent material - this is done with the appearances tab under Render.
There is no 'work bench' in Creo. There is part mode or assembly mode.
Wildfire:
Select component  View > Display Style > Transparent
Creo:
Select component then either
model tab > model display pulldown > component display style > transparent
view tab > model display pulldown > component display style > transparent
Re: Difference between Distance*D Offset*O
Please elaborate.  What are you referring to?
IN chamfer.. D*D and O*O i want to know the difference.
ur procedure for transparent we can do in assembly.. but im asking in part work bench
Thanks Dave for covering - got tied in a kaizen event.....
