I took this part from internet on which first i created revolve part, after i found difficulty on making round and slot whenever i used to make round and extrude option it will diretly takes me in round and extrude sub-option, but hear i required to edit a part with edit deifination then menu manger will open, with the help of which i redefine the feature.
same hear found a difficulty on Slot- extrude
i attached prt. file please see this
this part file will open on creo 2.0
I am student
I think is protrusion you can change some thing if you want
see this image you understand Principles of protrusion
dear friend,
i need to ask you how this command comes i know the procedure. But the problem is that how this dialog box appears and what is the procedure to get it, simply a panel appears when using editdefination any extrude or round option..
hello anyone please help me to get that command
