Anytime you use a large amount of created dimensions they are at risk of going away by some little change.
If you are really pressed for time, you can open a previous version from intralink and save a dxf.
Open the dxf and cut and paste all the dimensions back onto the drawing by using copy 0,0 to 0,0.
You can then at least reattach them instead of creating them all again.
What really sucks is if they are ordinate.
In Reply to Lyle Beidler:
I have a very strange situation that popped up here with Intralink 3.4 and
Wildfire3.
We have a designer/draftsman & an engineer working on the same project. The
designer finished detailing a weld assembly drawing & checked it and the
assembly in. He had the drawing fully detailed, with a large number of
dimensions. Then, the engineer checked out the assembly & drawing, and
added parts to the assembly. When he pulled up the drawing, the only
dimensions on it were shown dimensions for the parts he had just assembled.
All of the designer's work was gone. Any idea why this may have happened?
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
< http://www.mgsincorporated.com
