why on creo 3.0 the button guide ( up and right )opens the guide of creo 4.0 ?
see the pdf attacked
TY
It's a known issue. PTC will have to either fix it on their webserver or fix it in a future build of Creo 3.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS254679
All,
This is fixed in Creo 3 M120
Are you sure?. We are running M120 and the help button still takes us to the Creo 4.0 online help.
Tom,
My mistake. We have our config.pro pointing to Creo 3.0 help located on a server.
thanks for the answers
you can download and install Help on local disk to avoid this problem.
Info from CS253942 ...
it works
great
ty Martin
A work around is not the answer here!!!!
If there is a work around, it should be for Creo 4, not 3. PTC should put the Creo 3 documentation back into the correct area (http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html) and create a new site for the Creo 4 documentation. The address even has creo30 in the path!!!!!!!!!!
I shouldn't have to patch my installation because someone at PTC put the documentation for Creo 4 in the wrong spot.
