hi
I remember that the audit trail should have a history record whenever the part is modified. But recently, when i checked the audit history, i found that the only history was when and who stored the current revision. open xxx.prt.32, you get when and who stored the 32th revison. when you open xxx.prt.33, you get when and who stored this 33th revision, no info for the 32th revision.
some option is modified or what? what should i do to get all modification done to the model?
thank you very much.
linda
anyone knows how to get the full history in the audit trail report?
thank you.
