Hi all,
Is there a way to edit my customized Creo Illustrate callout to point to the ASM part attributes instead of the PRT part attributes? I'm working with a model that has the connector number metadata that I'm attempting to target in the ASM (highlighted in structure) and not the PRT. Most of the models I work with have the connector metadata in the PRT file and my custom callout works fine. Is there a way to modify the XML to get this to work? Please see my annotation and screenshots below.
Tom
My annotation to reference "REF_DES":
<annotation id="ref_des" hasLeaders="true">
<name>Ref_des</name>
<description>Reference Harness ID</description>
<tooltip>Reference Harness ID</tooltip>
<thumbnail url="itmtag_prop.png"/>
<leaders>
<line-style weight="1pt" color="#000000" halo="false" dashes="Solid" start="none" end="none"/>
</leaders>
<label canEdit="true">
<text font="Arial" size="10pt" color="#000000">
<useproperty category="Cable Parameters" name="REF_DES"/>
</text>
<shape type="rectangle" border="true"/>
</label>
</annotation>
Hi Marc,
I found a workaround but not a solution. My memory isn't the clearest, but essentially what I did to accomplish this was by highlighting the .asm and .prt in the BOM and editing the structure so that they're combined. It was good enough for what I was working on. I hope it helps you out.
Cheers,
Tom
