Creo View Mobile App Delete Files
cballantoni
How do you delete or remove the files that are loaded into the Creo View Mobile App?
Once loaded from iTunes or from e-mail.
The only way to delete files from Creo View Mobile Appis to use iTunes. Basically, its the same way as loading files into the App via iTunes. Select an existing file and hit the "delete" button.
