I work with Creo Schematics, I design electrical schematics,
I search solution to follow signals easily between the different handbook pages by clicking on the connections.
I would like to know if it is possible to create clickable links on the connections within the electrical schematics directly with the Creo Schematics software ?
If not possible, do you know a way to do that, a solution to propose me?
In result, I want a handbook containing electrical schematics in PDF format with the clickable links for jump page to page and to follow very easily the signals.
I look forward to hearing from you.
Kind regards.
J. GUERINOT
